Saltar al contenido principal
TiVo Premiere XL4 Hard Drive Replacement
Qué necesitas
  1. TiVo Premiere XL4 Hard Drive Replacement, Case: paso 1, imagen 1 de 1
    • Power down the TiVo Premiere XL4 by detaching the power cable from the unit and power source.
    • Allow the box to cool for at least 5 minutes before proceeding to the next step.
  2. TiVo Premiere XL4 Hard Drive Replacement: paso 2, imagen 1 de 2 TiVo Premiere XL4 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Remove the four 80 mm T10 screws from the back of the TiVo box using theTorx screwdriver.
  3. TiVo Premiere XL4 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Take the outer casing by sliding the top of the box off of the component carefully, making sure not to damage the surrounding components inside.
  4. TiVo Premiere XL4 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 3 TiVo Premiere XL4 Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 3 TiVo Premiere XL4 Hard Drive Replacement, Hard Drive: paso 4, imagen 3 de 3
    • Pinch the connector of the bundle of wires (the bundle having black, red, black and yellow wires) and gently remove from the motherboard.
    • Pinch the connector of the single flat wire and gently remove from motherboard.
  5. TiVo Premiere XL4 Hard Drive Replacement: paso 5, imagen 1 de 2 TiVo Premiere XL4 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Unscrew the following two 80 mm T10 screws connecting the hard drive to the bottom of the box using the Torx screwdriver.
    • Repeat on the other side of the hard drive.
    • There will be a total of four 80 mm T10 screws removed.
  6. TiVo Premiere XL4 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Remove hard drive from box.
  7. TiVo Premiere XL4 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Remove the marked (2) T10 screws and washers using a Torx Screwdriver.
    • Repeat on the opposite side for (2) T10 screws.
    • Remove the connecting cable.
    • Keep the fasteners if the hard drive needs to be replaced.
Conclusión
Frances Prewitt
Miembro Desde 10/22/18
661 Reputación
6 Guías creadas
Equipo
Baylor, Team S1-G1, Williams Fall 2018 Miembro de Baylor, Team S1-G1, Williams Fall 2018
BU-WILLIAMS-F18S1G1
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 1,102
