Saltar al contenido principal
Introducción
There are currently two methods being used to upgrade/replace TiVo Bolt HDDs. One is replacing the internal 2.5" drive, the other is using a 3.5" drive by drilling a hole in the casing and using a sata extension cable and providing an external power source as well as a separate housing. TiVos are particular about what type of HDD is used. The parts section included the most popular choices for internal HDD replacement options. This Guide will cover replacing the internal 2.5" HDD with another 2.5" HDD. You can use a drive greater than 3tb however the TiVo box will not auto format it. This Guide will not cover how to format a HDD for use in a TiVo if it is over 3tb.
  1. This screw is a different length than all the other screws.
    • This screw is a different length than all the other screws.
  2. Undo the clips to lift up the Cable card slot cover
    • Undo the clips to lift up the Cable card slot cover
  3. Do not attempt to remove the housing yet. Still 3 more screws and plastic clips holding it in place
    • Do not attempt to remove the housing yet. Still 3 more screws and plastic clips holding it in place
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. This shows the placement of the clips so you know where to place your plastic pics. Make sure to left this cover straight up when removing as you can see on the left side it has prongs that slide into the other part of the plastic housing.
    • This shows the placement of the clips so you know where to place your plastic pics.
    • Make sure to left this cover straight up when removing as you can see on the left side it has prongs that slide into the other part of the plastic housing.
  6. Case is still clipped in so do not attempt to remove the case yet Case is still clipped in so do not attempt to remove the case yet
    • Case is still clipped in so do not attempt to remove the case yet
  7. Plastic Pic placement shows where the clips are. I found it easy to use a 5th pic on the right to help separate the housing from the board
    • Plastic Pic placement shows where the clips are.
    • I found it easy to use a 5th pic on the right to help separate the housing from the board
  8. Once you undo this screw you can unplug the harddrive and left up the HDD to separate the HDD and tray from the Board
    • Once you undo this screw you can unplug the harddrive and left up the HDD to separate the HDD and tray from the Board
    • Then undo the screws holding the tray to the HDD. Put the Tray on you new HDD and screw it in.
  9. Afterwards I decided to go ahead and add the plastic routing clips on, which are not shown in the picture. Afterwards I decided to go ahead and add the plastic routing clips on, which are not shown in the picture. Afterwards I decided to go ahead and add the plastic routing clips on, which are not shown in the picture.
    • Afterwards I decided to go ahead and add the plastic routing clips on, which are not shown in the picture.
Conclusión
3 personas más completaron esta guía.
Jacob
Miembro Desde 22/09/18
247 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 30
Últimos 30 Días: 113
Todo El Tiempo: 537
