Saltar al contenido principal
Thustmaster Ferrari 458 Spider Racing Wheel motherboard Replacement
Qué necesitas
  1. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement: paso 2, imagen 1 de 2 Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement: paso 2, imagen 2 de 2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
  3. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement, Motherboard: paso 3, imagen 1 de 1
    • Using a small plastic opening tool, gently pry up the white connector that connects the USB cable to the board.
    • Cut the black cable as close to the board as possible.
    • Remove the three screws using PH2 screw driver.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S1-G33, Cagle Fall 2017 Miembro de USF Tampa, Team S1-G33, Cagle Fall 2017
USFT-CAGLE-F17S1G33
4 Miembros
5 Guías creadas
3 comentarios
how can I replace elastic cord?
geoff - Contestar
Just so every one knows its easier then changing a baby's arse for the first ten times if any one hasn’t yet I'm not gunna paint a picture I'm just going to sit here and smile. But as I was saying I found what was wrong just got to get my parts and fit as easy as that and if you don't know or butter for fingers then just let some other capable suspect do it, Save money.
scott_vernon85 - Contestar
Where did you get a replacement motherboard?
Paul Stewart - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 59
Todo El Tiempo: 5,429
