Saltar al contenido principal
Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement
Qué necesitas
  1. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement: paso 2, imagen 1 de 2 Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement: paso 2, imagen 2 de 2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
  3. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Wheel and Pedal Connection Port: paso 3, imagen 1 de 2 Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Wheel and Pedal Connection Port: paso 3, imagen 2 de 2
    • Using a small plastic opening tool, gently pry up the white connector that connects the pedals to the board.
    • By pulling up on both ends of the port you will be able to pull out the port to remove it.
Conclusión
2 personas más completaron esta guía.
Mario Nunez
Miembro Desde 10/18/17
421 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S1-G33, Cagle Fall 2017 Miembro de USF Tampa, Team S1-G33, Cagle Fall 2017
USFT-CAGLE-F17S1G33
4 Miembros
5 Guías creadas
2 comentarios
I just need to know where to get a replacement USB cable from ( the USB to the circular end part).
TheComfyCompie - Contestar
I need to know what USB cable connects the round cable end on the steerwheel to the Xbox one
Susan Witter - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 37
Todo El Tiempo: 5,591
