Saltar al contenido principal
Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement
Qué necesitas
  1. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: paso 2, imagen 1 de 2 Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: paso 2, imagen 2 de 2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
  3. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement, USB Cable Replacement: paso 3, imagen 1 de 2 Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement, USB Cable Replacement: paso 3, imagen 2 de 2
    • Using a small plastic opening tool, gently pry up the white connector that connects the USB cable to the board.
  4. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: paso 4, imagen 1 de 2 Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: paso 4, imagen 2 de 2
    • Desolder the black cable that connects the USB port to the motherboard.
    • For more information on how to solder and desolder connections, please visit this guide.
Conclusión
3 personas más completaron esta guía.
Mario Nunez
Miembro Desde 10/18/17
421 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S1-G33, Cagle Fall 2017 Miembro de USF Tampa, Team S1-G33, Cagle Fall 2017
USFT-CAGLE-F17S1G33
4 Miembros
5 Guías creadas
7 comentarios
kunt u mij vertellen waar ik het kabeltje kan kopen?
Rene
Rene Haeren - Contestar
Can you advise on where to obtain a new usb cable please? (clentonmalcolm@gmail.com)
Malcolm Clenton - Contestar
Have you solved it? I'm worried it's different from the regular usb line.
sunned -
Then wat where do u get usb cord to replace it some one plz explian
lilybaxter505 - Contestar
Oh man.. the first comment about this was 2019 and we both are still waiting for an answer huh
Hez van der Meij -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 14
Ultimos 30 días: 72
Todo El Tiempo: 8,996
