Saltar al contenido principal
Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement
Qué necesitas
  1. Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement: paso 2, imagen 1 de 2 Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement: paso 2, imagen 2 de 2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G33, Cagle Fall 2017 Miembro de USF Tampa, Team S1-G33, Cagle Fall 2017
USFT-CAGLE-F17S1G33
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 31
Todo El Tiempo: 5,564
