Introducción
Instructions on how to replace the RJ12 main cable
Qué necesitas
Use a Phillips driver to remove all screws at the bottom.
Use the Tweezers to carefully remove the wires from the sensors
Lift the tape and remove the cable
You can keep the original tape, add new tape or use some other method to stabilize the cable.
Casi Terminas!
To reassemble your pedal set, follow these instructions in reverse order.
Conclusión
