Saltar al contenido principal
Thrustmaster T Flight Hotas 4 Trigger Replacement
Qué necesitas
  1. Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: paso 1, imagen 1 de 2 Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: paso 1, imagen 2 de 2
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the four 15 mm J1 JIS head screws from the exterior of the joystick.
  2. Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: paso 2, imagen 1 de 3 Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: paso 2, imagen 2 de 3 Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: paso 2, imagen 3 de 3
    • Carefully remove the paneling of the joystick using your hands to pull the panels apart.
    • Be aware that the panels will fall apart when the screws are removed unless they are held together.
    • This metal piece must be put back into its correct position. If not it will impair the movement of the joystick's rudder mechanism.
  3. Thrustmaster T Flight Hotas 4 Trigger Replacement: paso 3, imagen 1 de 1
    • Remove the 8 mm J1 JIS head screw that is holding the trigger in place.
  4. Thrustmaster T Flight Hotas 4 Trigger Replacement: paso 4, imagen 1 de 3 Thrustmaster T Flight Hotas 4 Trigger Replacement: paso 4, imagen 2 de 3 Thrustmaster T Flight Hotas 4 Trigger Replacement: paso 4, imagen 3 de 3
    • Remove trigger and metal spring.
    • Remember to position the metal spring in the exact same place.
Conclusión
Aaron Banaga
Miembro Desde 09/11/17
526 Reputación
4 Guías creadas
Equipo
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Miembro de CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 3,370
