Introducción
Make sure you have a replacement ready! This will involve some drive formatting.
Partes
Carefully remove two Phillips screws with a Phillips 0 screwdriver
Remove the 4 identical Phillips screws with a Phillips 00 screw driver (they are on both sides).
4 personas más completaron esta guía.
Un Comentario
Almost perfect instructions. I do recommend removing the active pen first. Also it's a good idea to remind people that the active pen holder is screwed to the case cover from the inside and will come out as part of the cover.
