Saltar al contenido principal
ThinkPad Yoga 12 SSD Replacement
Qué necesitas
  1. ThinkPad Yoga 12 SSD Replacement, Screws: paso 1, imagen 1 de 3 ThinkPad Yoga 12 SSD Replacement, Screws: paso 1, imagen 2 de 3 ThinkPad Yoga 12 SSD Replacement, Screws: paso 1, imagen 3 de 3
    • Remove the ten Phillips screws using a Philips 00 screwdriver
  2. ThinkPad Yoga 12 SSD Replacement, Prying: paso 2, imagen 1 de 2 ThinkPad Yoga 12 SSD Replacement, Prying: paso 2, imagen 2 de 2
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 SSD Replacement, Lift off cover: paso 3, imagen 1 de 1
    • Lift off the cover, and you're done!
  4. ThinkPad Yoga 12 SSD Replacement, Remove SSD from the laptop: paso 4, imagen 1 de 2 ThinkPad Yoga 12 SSD Replacement, Remove SSD from the laptop: paso 4, imagen 2 de 2
    • Carefully remove two Phillips screws with a Phillips 0 screwdriver
    • Static sensitive components!
  5. ThinkPad Yoga 12 SSD Replacement: paso 5, imagen 1 de 2 ThinkPad Yoga 12 SSD Replacement: paso 5, imagen 2 de 2
    • Gently grab the plastic tab. Lift and pull the SSD assembly out of the computer
  6. ThinkPad Yoga 12 SSD Replacement, Remove enclosure: paso 6, imagen 1 de 2 ThinkPad Yoga 12 SSD Replacement, Remove enclosure: paso 6, imagen 2 de 2
    • Remove the 4 identical Phillips screws with a Phillips 00 screw driver (they are on both sides).
  7. ThinkPad Yoga 12 SSD Replacement, Done!: paso 7, imagen 1 de 2 ThinkPad Yoga 12 SSD Replacement, Done!: paso 7, imagen 2 de 2
    • Carefully remove the SSD enclosure.
    • Note: The SSD enclosure is made of thin metal. It can be easily deformed. Be careful when removing from the SSD.
Conclusión
6 personas más completaron esta guía.
[deleted]
Miembro Desde 03/18/18
1,324 Reputación
3 Guías creadas
Un comentario
Almost perfect instructions. I do recommend removing the active pen first. Also it's a good idea to remind people that the active pen holder is screwed to the case cover from the inside and will come out as part of the cover.
Dani Deitch - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 24
Todo El Tiempo: 4,924
