Saltar al contenido principal
ThinkPad Yoga 12 Bottom Cover Removal
Qué necesitas
  1. ThinkPad Yoga 12 Bottom Cover Removal, Screws: paso 1, imagen 1 de 3 ThinkPad Yoga 12 Bottom Cover Removal, Screws: paso 1, imagen 2 de 3 ThinkPad Yoga 12 Bottom Cover Removal, Screws: paso 1, imagen 3 de 3
    • Remove the ten Phillips screws using a Philips 00 screwdriver
  2. ThinkPad Yoga 12 Bottom Cover Removal, Prying: paso 2, imagen 1 de 2 ThinkPad Yoga 12 Bottom Cover Removal, Prying: paso 2, imagen 2 de 2
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 Bottom Cover Removal, Lift off cover: paso 3, imagen 1 de 1
    • Lift off the cover, and you're done!
Conclusión
To reassemble, place the bottom cover on and push until you hear a satisfying click. Keep doing this until the whole cover is secured. Then, screw all of the screws back in!
3 personas más completaron esta guía.
[deleted]
Miembro Desde 03/18/18
1,324 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 1,416
