Saltar al contenido principal
ThinkPad X1 Carbon Wireless Card Replacement
Qué necesitas
  1. ThinkPad X1 Carbon Wireless Card Replacement, Loosen Cover Screws: paso 1, imagen 1 de 1
    • Using the #0 Phillips screwdriver, loosen the seven cover screws. they will not come all of the way out.
  2. ThinkPad X1 Carbon Wireless Card Replacement: paso 2, imagen 1 de 1
    • Using the spudger pop the cover loose and remove.
  3. ThinkPad X1 Carbon Wireless Card Replacement, Disconnect Battery: paso 3, imagen 1 de 1
    • Use only plastic tools to disconnect battery cable
    • Slide battery connector in the direction if the arrow to disconnect.
    • You can leave the battery or remove it using the red circles for the screw locations.
  4. ThinkPad X1 Carbon Wireless Card Replacement: paso 4, imagen 1 de 1
    • Remove screw holding the wireless card in place.
  5. ThinkPad X1 Carbon Wireless Card Replacement, Remove Antenna Cables: paso 5, imagen 1 de 1
    • Carefully remove the antenna cables and slide out the card in the direction of the arrow.
    • The gray connector is on the top. The black connector is closer to the battery.
Conclusión
3 personas más completaron esta guía.
Mike
Miembro Desde 06/23/16
1,834 Reputación
5 Guías creadas
Equipo
iReconstruction Miembro de iReconstruction
Business
1 Miembro
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 50
Todo El Tiempo: 5,497
