Saltar al contenido principal
ThinkPad X1 Carbon SSD Replacement
Qué necesitas
  1. ThinkPad X1 Carbon SSD Replacement, Remove Bottom Cover: paso 1, imagen 1 de 1
    • Use phillips #2 screwdriver to loosen seven cover screws.
  2. ThinkPad X1 Carbon SSD Replacement, Remove Bottom Cover: paso 2, imagen 1 de 1
    • Use spudger to pop open bottom cover, remove and set aside.
  3. ThinkPad X1 Carbon SSD Replacement, Disconnect Battery: paso 3, imagen 1 de 1
    • Disconnect the battery connector from the main board by pulling the connector towards the battery.
  4. ThinkPad X1 Carbon SSD Replacement, Remove SSD Screw: paso 4, imagen 1 de 1
    • Use the # 2 phillips screwdriver and remove the screw holding the SSD in place.
  5. ThinkPad X1 Carbon SSD Replacement, Remove SSD: paso 5, imagen 1 de 1
    • Remove the SSD by sliding it out of the connector to the right.
Conclusión
11 personas más completaron esta guía.
Mike
Miembro Desde 06/23/16
1,834 Reputación
5 Guías creadas
Equipo
iReconstruction Miembro de iReconstruction
Business
1 Miembro
11 Guías creadas
7 comentarios
hi, can advise me which of the latest ssd 256/500 GB ssd's would work on a x1 carbon i5?
hardtail1969 - Contestar
Really need to put the version/generation of the x1 carbon.. The gen 1 does not look like this inside and I’m spending way too much time trying to figure out what SSD it will take
Eric Metzger - Contestar
Even for new models still can be used. same m.2 drive that might be located in the middle or top right of the device. Once the screws are off it is a very easy process.
jwalker8931 - Contestar
I just replaced the SSD on my gen 6 and the steps are so easy: undo 5 screws, open up, undo 1 screw to loosen the M.2 module, replace and put things back together. There is no need to mess around with the battery connection at all.
haivu - Contestar
A proper way, yes you need to disconnect the battery. You will learn it a hard way just a minor mistake, will blow your Mother Board and you will remember to disconnect them next time. The instruction is great.
Ryan Chau -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 17
Ultimos 7 días: 126
Ultimos 30 días: 510
Todo El Tiempo: 42,817
