Saltar al contenido principal
ThinkPad X1 Carbon Battery Replacement
Qué necesitas
  1. ThinkPad X1 Carbon Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Unscrew the seven screws located on the back of the device
  2. ThinkPad X1 Carbon Battery Replacement: paso 2, imagen 1 de 1
    • Slide the plastic the spudger along the edge of the device to separate the keyboard tray.
  3. ThinkPad X1 Carbon Battery Replacement: paso 3, imagen 1 de 1
    • Flip the device over and open it to lift the keyboard tray from the body of the device .
  4. ThinkPad X1 Carbon Battery Replacement: paso 4, imagen 1 de 1
    • Gently release the ribbon cable attached to the keyboard.
    • Gently Place keyboard tray to side.
  5. ThinkPad X1 Carbon Battery Replacement: paso 5, imagen 1 de 1
    • Unscrew the 4 screws holding the battery in place.
  6. ThinkPad X1 Carbon Battery Replacement: paso 6, imagen 1 de 1
    • Unlock and remove the ribbon cable running over the top of the battery.
  7. ThinkPad X1 Carbon Battery Replacement: paso 7, imagen 1 de 1
    • Gently pull the battery connection from the motherboard .
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 317
