Saltar al contenido principal
ThinkPad Edge E31 Underside Disassembly
Qué necesitas
  1. ThinkPad Edge E31 Underside Disassembly, Battery: paso 1, imagen 1 de 1
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
  2. ThinkPad Edge E31 Underside Disassembly: paso 2, imagen 1 de 1
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
  3. ThinkPad Edge E31 Underside Disassembly, ThinkPad Edge E31 Underside Disassembly: paso 3, imagen 1 de 1
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
Conclusión
Riley
Miembro Desde 03/19/17
601 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 328
