Introducción
Use this guide to replace a broken trackpad.
Qué necesitas
Use a Size 0 Philips screwdriver to loosen the nine screws on the bottom of the case. They will not come out entirely, but you will feel when they are loose enough.
You will need to remove the rubber pads from the bottom three screws using a pair of tweezers.
Remove the four screws securing the trackpad's bottom plate to the case.
After removing the bottom plate, remove the two screws securing the trackpad to the case.
Una persona más ha completado esta guía.
