Saltar al contenido principal
Thermaltake Theron Plus Scroll Wheel Replacement
Qué necesitas
  1. Thermaltake Theron Plus Scroll Wheel Replacement, Top cover: paso 1, imagen 1 de 3 Thermaltake Theron Plus Scroll Wheel Replacement, Top cover: paso 1, imagen 2 de 3 Thermaltake Theron Plus Scroll Wheel Replacement, Top cover: paso 1, imagen 3 de 3
    • Remove the plastic cover and pack of weights.
    • Remove the two 1.0 mm foam covers with tweezers.
    • Peel away the plastic screw cover with tweezers.
  2. Thermaltake Theron Plus Scroll Wheel Replacement: paso 2, imagen 1 de 2 Thermaltake Theron Plus Scroll Wheel Replacement: paso 2, imagen 2 de 2
    • Remove the four 1.0 mm screws with a Ph #1 screwdriver.
    • Gently remove the top of the mouse.
  3. Thermaltake Theron Plus Scroll Wheel Replacement, Scroll Wheel: paso 3, imagen 1 de 2 Thermaltake Theron Plus Scroll Wheel Replacement, Scroll Wheel: paso 3, imagen 2 de 2
    • Grasp the scroll wheel and wiggle it out in the direction opposite the socket.
    • Be careful not to break the small plastic arms on either side of the scroll.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 873
