Saltar al contenido principal
Thermaltake Theron Plus 5-pin USB Cord Replacement
Qué necesitas
  1. Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: paso 1, imagen 1 de 3 Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: paso 1, imagen 2 de 3 Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: paso 1, imagen 3 de 3
    • Remove the plastic cover and pack of weights.
    • Remove the two 1.0 mm foam covers with tweezers.
    • Peel away the plastic screw cover with tweezers.
  2. Thermaltake Theron Plus 5-pin USB Cord Replacement: paso 2, imagen 1 de 2 Thermaltake Theron Plus 5-pin USB Cord Replacement: paso 2, imagen 2 de 2
    • Remove the four 1.0 mm screws with a Ph #1 screwdriver.
    • Gently remove the top of the mouse.
  3. Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: paso 3, imagen 1 de 3 Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: paso 3, imagen 2 de 3 Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: paso 3, imagen 3 de 3
    • Locate the 5-pin connector on the mouse's motherboard.
    • Use the tweezers to carefully pull the 5-pin connector off. Do this by grasping the connector and wiggling it back and forth until it is off.
    • Once removed, place new 5-pin connector on in the same way.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 607
