Saltar al contenido principal
The Sharper Image Literati Tablet SD Port Replacement
Qué necesitas
  1. The Sharper Image Literati Tablet SD Port Replacement, Battery: paso 1, imagen 1 de 1
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
  2. The Sharper Image Literati Tablet SD Port Replacement: paso 2, imagen 1 de 1
    • Desolder the battery wires from the circuit board.
  3. The Sharper Image Literati Tablet SD Port Replacement: paso 3, imagen 1 de 1
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
  4. The Sharper Image Literati Tablet SD Port Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
  5. The Sharper Image Literati Tablet SD Port Replacement, SD Port: paso 5, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
  6. The Sharper Image Literati Tablet SD Port Replacement: paso 6, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove three 4 mm screws from the circuit board containing the headphone jack and power jack.
  7. The Sharper Image Literati Tablet SD Port Replacement: paso 7, imagen 1 de 1
    • Remove the circuit board.
  8. The Sharper Image Literati Tablet SD Port Replacement: paso 8, imagen 1 de 1
    • Unclip ZIF clip from the chip and unplug ribbon cable.
  9. The Sharper Image Literati Tablet SD Port Replacement: paso 9, imagen 1 de 1
    • Detach the peripheral edge with plastic wedge.
    • This may require a little hard pulling.
  10. The Sharper Image Literati Tablet SD Port Replacement: paso 10, imagen 1 de 1
    • Remove peripheral silver edge.
  11. The Sharper Image Literati Tablet SD Port Replacement: paso 11, imagen 1 de 1
    • Remove screws from the large metal shielding.
  12. The Sharper Image Literati Tablet SD Port Replacement: paso 12, imagen 1 de 1
    • Remove the silver backing plate and the adhered SD port chip.
Conclusión
Spencer Dodder
Miembro Desde 03/21/18
560 Reputación
4 Guías creadas
Equipo
IUPUI, Team S5-G4, Baechle Spring 2018 Miembro de IUPUI, Team S5-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G4
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 245
