Saltar al contenido principal
The Sharper Image Literati Tablet Battery Replacement
Qué necesitas
  1. The Sharper Image Literati Tablet Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
  2. The Sharper Image Literati Tablet Battery Replacement: paso 2, imagen 1 de 1
    • Desolder the battery wires from the circuit board.
  3. The Sharper Image Literati Tablet Battery Replacement: paso 3, imagen 1 de 1
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
  4. The Sharper Image Literati Tablet Battery Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
Linea de Meta
Una persona más ha completado esta guía.
Spencer Dodder
Miembro Desde 03/21/18
560 Reputación
4 Guías creadas
Equipo
IUPUI, Team S5-G4, Baechle Spring 2018 Miembro de IUPUI, Team S5-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G4
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 815
