Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Partes
No se especificaron partes.
  1. Place The Claw machine in the up-right position with the control knobs facing you.
    • Place The Claw machine in the up-right position with the control knobs facing you.
  2. Turn The Claw machine upside-down placing the top cover on the surface of your work area.
    • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
  3. Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
    • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
    • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
  4. Kit de Destornilladores Manta
    112 bits for every fix.
    Upgrade Your Toolbox
  5. Turn The Claw machine back to the upright position with controls facing you.
    • Turn The Claw machine back to the upright position with controls facing you.
  6. Remove the top cover of The Claw machine.
    • Remove the top cover of The Claw machine.
  7. Remove the ten 6 mm phillips #1 screws from the top flange. Remove the ten 6 mm phillips #1 screws from the top flange.
    • Remove the ten 6 mm phillips #1 screws from the top flange.
  8. Lift the flange upward and off to the side of the machine.
    • Lift the flange upward and off to the side of the machine.
    • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
    • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
Conclusión
Alain Pierre
Miembro Desde 22/03/16
1,149 Reputación
9 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 50
