Introducción
If the clear plastic case on your claw device is broken or damaged, it can easily be replaced. This required the opening of the top cover of your claw device in order to access the clear plastic panels. Using this easy to follow replacement guide will make case replacement an easy task.
Qué necesitas
Place The Claw machine in the up-right position with the control knobs facing you.
The glass you intend to replace will have four 6mm #1 phillips head screws on either side located in the silver corner pieces.
2 personas más completaron esta guía.
