Saltar al contenido principal
The Beatles Rock Band Hofner Bass Directional Pad Replacement
Qué necesitas
  1. The Beatles Rock Band Hofner Bass Directional Pad Replacement, Back Plate: paso 1, imagen 1 de 1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Directional Pad Replacement: paso 2, imagen 1 de 1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Directional Pad Replacement: paso 3, imagen 1 de 2 The Beatles Rock Band Hofner Bass Directional Pad Replacement: paso 3, imagen 2 de 2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
  4. The Beatles Rock Band Hofner Bass Directional Pad Replacement, Directional Pad: paso 4, imagen 1 de 2 The Beatles Rock Band Hofner Bass Directional Pad Replacement, Directional Pad: paso 4, imagen 2 de 2
    • Use a J1 Phillips screwdriver to remove the six screws 10mm around the brown button cover.
  5. The Beatles Rock Band Hofner Bass Directional Pad Replacement: paso 5, imagen 1 de 1
    • Remove the directional pad button,
Conclusión
Jacob
Miembro Desde 01/25/17
601 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 8-4, Banghart Winter 2017 Miembro de Cal Poly, Team 8-4, Banghart Winter 2017
CPSU-BANGHART-W17S8G4
3 Miembros
6 Guías creadas
Un comentario
I need help re-assembling the Effect Switch. I have a tiny spring and steel ball that I don't know how to put back together.
Jay Kap - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 375
