Saltar al contenido principal
The Beatles Rock Band Drum Set Drum Pad Replacement
Qué necesitas
  1. The Beatles Rock Band Drum Set Drum Pad Replacement, Drum Pad: paso 1, imagen 1 de 2 The Beatles Rock Band Drum Set Drum Pad Replacement, Drum Pad: paso 1, imagen 2 de 2
    • Pry the drum pad off of the drum set.
    • This will take significant force, but the rubber on the drum pad can withstand the force.
  2. The Beatles Rock Band Drum Set Drum Pad Replacement: paso 2, imagen 1 de 2 The Beatles Rock Band Drum Set Drum Pad Replacement: paso 2, imagen 2 de 2
    • Remove the small wire clip shown in the picture.
    • If this wire is already disconnected, that is most likely the cause for the drum pad not working.
  3. The Beatles Rock Band Drum Set Drum Pad Replacement: paso 3, imagen 1 de 1
    • Remove the four Phillips size J0 screws supporting the hit sensor.
    • There is a small plastic disk and a spring in the support; be sure not to lose it.
  4. The Beatles Rock Band Drum Set Drum Pad Replacement: paso 4, imagen 1 de 1
    • The sensor can be peeled off of the drum pad.
Conclusión
2 personas más completaron esta guía.
Zach Richter
Miembro Desde 01/24/17
549 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 13-3, Banghart Winter 2017 Miembro de Cal Poly, Team 13-3, Banghart Winter 2017
CPSU-BANGHART-W17S13G3
4 Miembros
5 Guías creadas
Un comentario
Where can you buy replacement sensor?
Barry Howard - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 18
Ultimos 30 días: 69
Todo El Tiempo: 8,119
