Introducción
In this guide we will show how to remove the display to replace it if broken.
- incomplete we currently do not know how to do this and can find no information on it
Herramientas
Partes
No se especificaron partes.
Grab the back of the calculator with one hand and the cover with the other.
Pull the cover off from one of the sides for easy removal.
"Locking Tab"
To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
Then with the front of the calculator facing down, pull up on the back cover.
The calculator should now be orientated with the front facing down, as shown in picture 2.
Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
Now simply remove the battery.
Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator.
Pull the motherboard up while holding the rest of the calculator firmly in place
The motherboard has now separated from the rest of the calculator
Using a #00 Philip Screwdriver remove the screw located on the left side of a spring-like object located near the center of the motherboard.
Una persona más ha completado esta guía.
