Saltar al contenido principal
Texas Instruments TI-92 Batteries Replacement
Qué necesitas
  1. Texas Instruments TI-92 Batteries Replacement, Back Cover: paso 1, imagen 1 de 3 Texas Instruments TI-92 Batteries Replacement, Back Cover: paso 1, imagen 2 de 3 Texas Instruments TI-92 Batteries Replacement, Back Cover: paso 1, imagen 3 de 3
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
  2. Texas Instruments TI-92 Batteries Replacement: paso 2, imagen 1 de 2 Texas Instruments TI-92 Batteries Replacement: paso 2, imagen 2 de 2
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
  3. Texas Instruments TI-92 Batteries Replacement: paso 3, imagen 1 de 2 Texas Instruments TI-92 Batteries Replacement: paso 3, imagen 2 de 2
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
  4. Texas Instruments TI-92 Batteries Replacement, Batteries: paso 4, imagen 1 de 3 Texas Instruments TI-92 Batteries Replacement, Batteries: paso 4, imagen 2 de 3 Texas Instruments TI-92 Batteries Replacement, Batteries: paso 4, imagen 3 de 3
    • The Batteries are now exposed and the calculator is face down with the back towards you.
    • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
    • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
    • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
    • Now simply remove the battery.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 15-51, Garner Spring 2010 Miembro de Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 24
Todo El Tiempo: 6,928
