Saltar al contenido principal
Texas Instruments TI-83 Plus Backup Battery Replacement
Qué necesitas
  1. Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: paso 1, imagen 1 de 2 Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: paso 1, imagen 2 de 2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Backup Battery Replacement: paso 2, imagen 1 de 1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Backup Battery Replacement: paso 3, imagen 1 de 1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
Conclusión
Clay
Miembro Desde 10/01/12
38 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 18-37, Regan Fall 2012 Miembro de Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Miembros
5 Guías creadas
Un comentario
Will this wipe the memory?
John Osborne - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 77
Todo El Tiempo: 21,100
