Introducción
Buttons will sometimes become cracked or damaged, or they may fall out. This guide shows you how to access, remove, and replace the buttons.
Qué necesitas
Locate battery cover on the back of the case.
Slide battery cover to the right reveal the batteries.
Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
Unscrew four 7.15 mm screws from back casing.
Using the blue plastic opener tool along the seam of the case, pry off front casing.
Using a Philips PH0 screwdriver, remove the 6 screws. 2 from the top of the Motherboard, 2 from the middle, and 2 from the bottom of the Motherboard.
Using a Phillips Ph0 screwdriver, remove 4 screws from the screen mount.
Using the blue plastic opening tool, pry the Motherboard up.
Using the blue plastic opening tool, pry up the screen from the screen mount.
Check the rubber mat for damage or obstruction at the location of non-functioning buttons.
Flip the mat over to assess dirt and damage.
Check the back of the buttons for damage or obstructions.
If obstructions are present, clear them.
