Saltar al contenido principal
Texas Instruments TI-80 Back Casing Replacement
Qué necesitas
  1. Texas Instruments TI-80 Back Casing Replacement, Batteries: paso 1, imagen 1 de 1
    • Locate battery cover on the back of the case.
    • Slide battery cover to the right reveal the batteries.
  2. Texas Instruments TI-80 Back Casing Replacement: paso 2, imagen 1 de 1
    • Remove battery cover.
    • Slide the red lock down.
    • Slide the metal tab to the right of the top battery.
    • Remove the 3-Volt Lithium Coin Cell Battery.
    • Slide the red lock up.
    • Slide the metal tab to the right of the bottom battery.
  3. Texas Instruments TI-80 Back Casing Replacement, Back Case: paso 3, imagen 1 de 3 Texas Instruments TI-80 Back Casing Replacement, Back Case: paso 3, imagen 2 de 3 Texas Instruments TI-80 Back Casing Replacement, Back Case: paso 3, imagen 3 de 3
    • Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
    • Unscrew four 7.15 mm screws from back casing.
    • Using the blue plastic opener tool along the seam of the case, pry off front casing.
    • Start prying from the bottom of the calculator as the casing hooks into the top.
Conclusión
Calvin
Miembro Desde 01/08/15
201 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 273
