Introducción
This guide demonstrates and describes proper removal and replacement of the back casing. It is needed to access other parts for repair or replacement.
Qué necesitas
Locate battery cover on the back of the case.
Slide battery cover to the right reveal the batteries.
Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
Unscrew four 7.15 mm screws from back casing.
Using the blue plastic opener tool along the seam of the case, pry off front casing.
Casi Terminas!
Conclusión
