Saltar al contenido principal
Texas Instruments TI BA II PLUS Battery Replacement
Qué necesitas
  1. Texas Instruments TI BA II PLUS  Battery Replacement, Battery: paso 1, imagen 1 de 2 Texas Instruments TI BA II PLUS  Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Switch off the calculator by pressing the button at the top right corner.
  2. Texas Instruments TI BA II PLUS  Battery Replacement: paso 2, imagen 1 de 1
    • Turn over the calculator so the backside of the calculator is facing upwards.
    • Remove the four 2mm Phillips #00 screws from the bottom cover.
  3. Texas Instruments TI BA II PLUS  Battery Replacement: paso 3, imagen 1 de 1
    • Open a small gap at the bottom of the calculator, using a spudger or your fingers.
    • Move your thumb from the bottom edge to the top.
    • Be gentle when separating the cases to avoid breaking the clips.
  4. Texas Instruments TI BA II PLUS  Battery Replacement: paso 4, imagen 1 de 3 Texas Instruments TI BA II PLUS  Battery Replacement: paso 4, imagen 2 de 3 Texas Instruments TI BA II PLUS  Battery Replacement: paso 4, imagen 3 de 3
    • Use a spudger to remove the battery from the cage at the bottom of the motherboard.
  5. Texas Instruments TI BA II PLUS  Battery Replacement: paso 5, imagen 1 de 1
    • Replace the battery with the new CR2032 Lithium Battery in the battery cage.
  6. Texas Instruments TI BA II PLUS  Battery Replacement: paso 6, imagen 1 de 2 Texas Instruments TI BA II PLUS  Battery Replacement: paso 6, imagen 2 de 2
    • Reattach the calculator cases, beginning from the top edge.
    • Use the Phillips #00 screwdriver to replace the 2.00 mm screws.
Linea de Meta
3 personas más completaron esta guía.
Peipei Yu
Miembro Desde 01/12/21
214 Reputación
1 Guía escrita
Un comentario
It's amazing that this calculator can break. I am an accountant student in college and despite modern technologies and the rather powerful functionality of modern smartphones, I like to use just such a calculator for financial calculations.
AlGorFun - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 23
Ultimos 7 días: 170
Ultimos 30 días: 713
Todo El Tiempo: 21,933
