Saltar al contenido principal
Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement
Qué necesitas
  1. Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement, Open casing: paso 1, imagen 1 de 3 Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement, Open casing: paso 1, imagen 2 de 3 Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement, Open casing: paso 1, imagen 3 de 3
    • Unlatch hooks all around the left casing (three on each side)
    • Carefully lift cover, fold it over and tape it to the head piece to get it out of the way. The NFC antenna is glued to the cover. Two wires connect it to the bundle.
    • Pry battery out w/ a spatula. You'll gain access to the speaker cables and can unsolder and replace the battery, if needed.
    • In case you need to get to the speaker, see https://de.ifixit.com/Anleitung/Teufel+A... for details.
Conclusión
Una persona más ha completado esta guía.
andre
Miembro Desde 03/12/12
1,701 Reputación
4 Guías creadas
Un comentario
Thank you very much for this guide!
Patch - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 414
