Saltar al contenido principal
Tengda S5 Plus Speakers Replacement
Qué necesitas
  1. Tengda S5 Plus Speakers Replacement, Back Panel: paso 1, imagen 1 de 1
    • Place the phone screen-side down.
  2. Tengda S5 Plus Speakers Replacement: paso 2, imagen 1 de 2 Tengda S5 Plus Speakers Replacement: paso 2, imagen 2 de 2
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Speakers Replacement, Speakers: paso 3, imagen 1 de 1
    • Using either your thumb or an iFixit opening tool, remove the battery and set it aside.
  4. Tengda S5 Plus Speakers Replacement: paso 4, imagen 1 de 1
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
  5. Tengda S5 Plus Speakers Replacement: paso 5, imagen 1 de 2 Tengda S5 Plus Speakers Replacement: paso 5, imagen 2 de 2
    • Using the plastic opening tool, create space between the front screen and the metal casing.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Speakers Replacement: paso 6, imagen 1 de 2 Tengda S5 Plus Speakers Replacement: paso 6, imagen 2 de 2
    • Using an iFixit opening tool, remove the speakers.
    • Do not be afraid to use a little force. The speakers are glued onto the phone, not wired.
Conclusión
Andrew Lam
Miembro Desde 04/23/15
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 14-9, Amido Spring 2015 Miembro de Cal Poly, Team 14-9, Amido Spring 2015
CPSU-AMIDO-S15S14G9
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 8
Todo El Tiempo: 323
