Saltar al contenido principal
Tengda S5 Plus Rear Camera Replacement
Qué necesitas
  1. Tengda S5 Plus Rear Camera Replacement, Back Panel: paso 1, imagen 1 de 1
    • Place the phone screen-side down.
  2. Tengda S5 Plus Rear Camera Replacement: paso 2, imagen 1 de 2 Tengda S5 Plus Rear Camera Replacement: paso 2, imagen 2 de 2
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Rear Camera Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
  4. Tengda S5 Plus Rear Camera Replacement, Rear Camera: paso 4, imagen 1 de 1
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
    • Keep these screws in a safe place. They are very small and easy to lose.
  5. Tengda S5 Plus Rear Camera Replacement: paso 5, imagen 1 de 2 Tengda S5 Plus Rear Camera Replacement: paso 5, imagen 2 de 2
    • Using the plastic opening tool, create space between the front screen and the metal casing.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Rear Camera Replacement: paso 6, imagen 1 de 1
    • Place the phone facing screen down.
    • Using the plastic prying tool, gently disconnect the black connector cable.
    • The connector cable should easy snap out with little force.
  7. Tengda S5 Plus Rear Camera Replacement: paso 7, imagen 1 de 1
    • Using the plastic prying tool, pry the camera from the tape holding it in place.
    • Be careful not to rip the tape.
Conclusión
2 personas más completaron esta guía.
Jholmesford
Miembro Desde 04/21/15
188 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 14-9, Amido Spring 2015 Miembro de Cal Poly, Team 14-9, Amido Spring 2015
CPSU-AMIDO-S15S14G9
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 268
