Qué necesitas
Disconnect the digitizer cable from is socket, flip the brown clasp up from indicated edge and gently remove the cable.
Separate the logic board from front display. Apply heat to the front glass to loosen the adhesive, using a prying tool to separate the board. Be careful and move slowly, it is very strong.
Be careful to remove the display first from the right side as there are clips along the left side.
Ensure not to damage the LCD cable, remove once accessible by releasing the brown clasp from indicated side.
