Introducción
This is a guide for replacing strings on a Telecaster-style guitar, whether you’re replacing broken strings or re-stringing your guitar. While Fender makes the original, most popular Telecasters, there are several different brands which produce them, and this guide will demonstrate how to navigate this unique guitar body and its components.
Use caution when handling guitar strings, as the ends are razor-sharp.
Qué necesitas
Start with the low E string (the furthest on the right). Unwind the string by turning the tuning peg counter-clockwise.
Keep the string secure by placing one finger on the string's nut slot.
After unwinding the string, the segment coiled around the post will come loose. Pull the string out of the post.
Pushing the end of the string to the bottom and the outside segment to the guitar head, turn the tuning peg clockwise.
When the string is tight enough, you may release it. Make sure the string fits securely within the nut slot.
Using a tuner of your choice, tighten the guitar string until it matches the correct pitch.
2 personas más completaron esta guía.
