Saltar al contenido principal
Tektro Aires Disc Brakes Brake Pad Replacement
Qué necesitas
  1. Tektro Aires Disc Brakes Brake Pad Replacement, Brake Pad: paso 1, imagen 1 de 1
    • Bend the retention pins straight using a pair of needle nose pliers.
  2. Tektro Aires Disc Brakes Brake Pad Replacement: paso 2, imagen 1 de 2 Tektro Aires Disc Brakes Brake Pad Replacement: paso 2, imagen 2 de 2
    • Loosen the two mounting bolts using a 5mm Hex Key.
    • Different bike models will have the mounting points in different locations.
  3. Tektro Aires Disc Brakes Brake Pad Replacement: paso 3, imagen 1 de 1
    • After removing the bolts pull of the brake caliper from the brake disc.
  4. Tektro Aires Disc Brakes Brake Pad Replacement: paso 4, imagen 1 de 1
    • Using the needle nose pliers remove the retention pin by pulling on it.
  5. Tektro Aires Disc Brakes Brake Pad Replacement: paso 5, imagen 1 de 1
    • Remove the brake pads by pulling on them and realesing them from the caliper.
  6. Tektro Aires Disc Brakes Brake Pad Replacement: paso 6, imagen 1 de 1
    • Place the spring on the new Tektro Disc Brake Pad as shown.
    • The other brake pad will go on the spring opposite the first brake pad.
Conclusión
  • The steps for the front wheel are the same as the back wheel.
  • Follow steps in reverse for reassembly.
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 72
Ultimos 30 días: 226
Todo El Tiempo: 5,745
