Introducción
This guide will help you resolve any problem with your speaker on your Teddy Ruxpin model #17262DS. If the volume, sound quality, or general audio qualities of your bear are lacking this guide should help you fix those issues. A Phillips #1 screwdriver is required to complete this guide. Desoldering is also required so be sure to look at the desoldering guide for help.
Qué necesitas
Remove the vest covering the back of the bear.
Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
Unscrew the eleven circled 12.5mm Phillips #1 screws.
Remove the top of the housing to access the electronics inside.
Unscrew the two 12.5mm Phillips #1 screws holding the speaker cap on and remove the speaker cap.
Una persona más ha completado esta guía.
