Saltar al contenido principal
Teddy Ruxpin Eyes Replacement
Qué necesitas
  1. Teddy Ruxpin Eyes Replacement, Battery: paso 1, imagen 1 de 2 Teddy Ruxpin Eyes Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Eyes Replacement: paso 2, imagen 1 de 1
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Eyes Replacement: paso 3, imagen 1 de 1
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Eyes Replacement, Arms: paso 4, imagen 1 de 3 Teddy Ruxpin Eyes Replacement, Arms: paso 4, imagen 2 de 3 Teddy Ruxpin Eyes Replacement, Arms: paso 4, imagen 3 de 3
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Eyes Replacement: paso 5, imagen 1 de 1
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Eyes Replacement: paso 6, imagen 1 de 3 Teddy Ruxpin Eyes Replacement: paso 6, imagen 2 de 3 Teddy Ruxpin Eyes Replacement: paso 6, imagen 3 de 3
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Eyes Replacement: paso 7, imagen 1 de 2 Teddy Ruxpin Eyes Replacement: paso 7, imagen 2 de 2
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Eyes Replacement: paso 8, imagen 1 de 2 Teddy Ruxpin Eyes Replacement: paso 8, imagen 2 de 2
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Eyes Replacement: paso 9, imagen 1 de 1
    • Unplug the arms from the main body.
  10. Teddy Ruxpin Eyes Replacement, Housing Cover: paso 10, imagen 1 de 3 Teddy Ruxpin Eyes Replacement, Housing Cover: paso 10, imagen 2 de 3 Teddy Ruxpin Eyes Replacement, Housing Cover: paso 10, imagen 3 de 3
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
  11. Teddy Ruxpin Eyes Replacement, Eyes: paso 11, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
  12. Teddy Ruxpin Eyes Replacement: paso 12, imagen 1 de 2 Teddy Ruxpin Eyes Replacement: paso 12, imagen 2 de 2
    • Unplug the two sets of wires connected to the back of the eyes by using moderate to high force.
  13. Teddy Ruxpin Eyes Replacement: paso 13, imagen 1 de 1
    • Once those wires are disconnected, desolder the wires connected from the eye motherboard.
Conclusión
2 personas más completaron esta guía.
Jayin Patel
Miembro Desde 01/23/20
406 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S18-G5, White Winter 2020 Miembro de Cal Poly, Team S18-G5, White Winter 2020
CPSU-WHITE-W20S18G5
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 29
Todo El Tiempo: 1,308
