Introducción
If your Teddy Ruxpin is not turning on you may need to replace the battery. This is a replacement guide for removing the batteries from the Teddy Ruxpin model #17262DS. For this guide, you will need four double AA batteries and a Phillips #2 screwdriver head. This replacement guide should be quick and easy.
Qué necesitas
Remove the vest covering the back of the bear.
Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
2 personas más completaron esta guía.
