Saltar al contenido principal
Technostar Sandwich Toaster Thermal Fuse Replacement
Qué necesitas
  1. Technostar Sandwich Toaster Thermal Fuse Replacement, Thermal Fuse: paso 1, imagen 1 de 1
    • Open the toaster.
    • Remove the four screws which attach the mold.
  2. Technostar Sandwich Toaster Thermal Fuse Replacement: paso 2, imagen 1 de 2 Technostar Sandwich Toaster Thermal Fuse Replacement: paso 2, imagen 2 de 2
    • Remove the mold to get access to the heating coil.
  3. Technostar Sandwich Toaster Thermal Fuse Replacement: paso 3, imagen 1 de 1
    • Find the thermofuse.
  4. Technostar Sandwich Toaster Thermal Fuse Replacement: paso 4, imagen 1 de 2 Technostar Sandwich Toaster Thermal Fuse Replacement: paso 4, imagen 2 de 2
    • Cut the two wires that connect to the thermal fuse.
  5. Technostar Sandwich Toaster Thermal Fuse Replacement: paso 5, imagen 1 de 2 Technostar Sandwich Toaster Thermal Fuse Replacement: paso 5, imagen 2 de 2
    • Align the thermal fuse with the open wires.
    • Put the spade connectors over the wires.
    • Using pliers, clamp the wires together.
  6. Technostar Sandwich Toaster Thermal Fuse Replacement: paso 6, imagen 1 de 1
    • Replace the molds.
    • Replace the four screws which attach the mold.
Linea de Meta
4 personas más completaron esta guía.
2 comentarios
where did u find the replacement fuse? I need a thermal fuse for Breville BSG520XL Panini Duo Grill
mortaz - Contestar
how do i test that the reason that my toaster is not working is actually the thermal fuse?
itzsabag - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 31
Todo El Tiempo: 4,076
