Saltar al contenido principal
Teac DC-D2831 Drive Belt replacement
Qué necesitas
  1. Teac DC-D2831 Drive Belt replacement, Drive Belt: paso 1, imagen 1 de 2 Teac DC-D2831 Drive Belt replacement, Drive Belt: paso 1, imagen 2 de 2
    • Separate the turntable from the top of the record player by lifting straight up.
  2. Teac DC-D2831 Drive Belt replacement: paso 2, imagen 1 de 1
    • Check the belt to see if it is off the motor or turntable. If the belt is damaged (tearing or lack of smoothness) replace the belt with a new one. If it is off track, realign accordingly.
    • Do not stretch the belt too far as it may break.
  3. Teac DC-D2831 Drive Belt replacement: paso 3, imagen 1 de 3 Teac DC-D2831 Drive Belt replacement: paso 3, imagen 2 de 3 Teac DC-D2831 Drive Belt replacement: paso 3, imagen 3 de 3
    • Once the belt is ready to go, re-wrap the belt around the turntable wheel and, keeping it around the wheel, wrap it around the motor (indicated by the red circle).
    • It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel.
  4. Teac DC-D2831 Drive Belt replacement: paso 4, imagen 1 de 1
    • Once the belt has been re-applied and the turntable re-attached, stand the record player back up.
Conclusión
To reassemble your device, follow these instructions in reverse order and complete the disassembly guide in reverse order.
2 personas más completaron esta guía.
Charles Lockner
Miembro Desde 09/17/12
115 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 2-61, Propen Fall 2012 Miembro de Cal Poly, Team 2-61, Propen Fall 2012
CPSU-PROPEN-F12S2G61
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 3,592
