Saltar al contenido principal
Tea Kettle Switch Replacement
Qué necesitas
  1. Tea Kettle Switch Replacement, Switch: paso 1, imagen 1 de 3 Tea Kettle Switch Replacement, Switch: paso 1, imagen 2 de 3 Tea Kettle Switch Replacement, Switch: paso 1, imagen 3 de 3
    • Before you start, disconnect the device from its power source.
    • Remove the two bottom screws.
    • Remove the two top screws.
    • Remove the handle from the kettle.
  2. Tea Kettle Switch Replacement: paso 2, imagen 1 de 2 Tea Kettle Switch Replacement: paso 2, imagen 2 de 2
    • Pull out the switch.
    • If you pull too hard, you may dislodge another part as well as the spring that are both positioned behind the switch.
  3. Tea Kettle Switch Replacement: paso 3, imagen 1 de 1
    • Click the replacement switch back into the handle part.
  4. Tea Kettle Switch Replacement: paso 4, imagen 1 de 1
    • Insert the light back into the switch.
    • This might take some extra attention, so be precise.
  5. Tea Kettle Switch Replacement: paso 5, imagen 1 de 1
    • Place the handle part back on the frame.
  6. Tea Kettle Switch Replacement: paso 6, imagen 1 de 1
    • Plug in the kettle.
    • Press down on the switch to check if it works again.
Conclusión
6 personas más completaron esta guía.
3 comentarios
How much would it cost to repair this kettle switch live points?
Bheki Valoyi - Contestar
How much would it cost to fix the tea kettle switch live points?
Can the kettle gadgets be replaced with another one
Michael Ombech - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 37
Ultimos 30 días: 163
Todo El Tiempo: 24,955
