Saltar al contenido principal
Taylor Precision Product 3831S Kitchen Scale Battery Replacement
Qué necesitas
  1. Taylor Precision Product 3831S Kitchen Scale Battery Replacement, Battery: paso 1, imagen 1 de 2 Taylor Precision Product 3831S Kitchen Scale Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Grab your scale and flip it over to get started.
    • Remove the small screw on the battery housing cover using the Phillips #00 screwdriver.
  2. Taylor Precision Product 3831S Kitchen Scale Battery Replacement: paso 2, imagen 1 de 2 Taylor Precision Product 3831S Kitchen Scale Battery Replacement: paso 2, imagen 2 de 2
    • Next, push the tab in and remove the battery covering.
  3. Taylor Precision Product 3831S Kitchen Scale Battery Replacement: paso 3, imagen 1 de 3 Taylor Precision Product 3831S Kitchen Scale Battery Replacement: paso 3, imagen 2 de 3 Taylor Precision Product 3831S Kitchen Scale Battery Replacement: paso 3, imagen 3 de 3
    • Carefully remove the dead battery.
  4. Taylor Precision Product 3831S Kitchen Scale Battery Replacement: paso 4, imagen 1 de 1
    • With the indented side facing the scale, secure the new battery in the battery housing.
  5. Taylor Precision Product 3831S Kitchen Scale Battery Replacement: paso 5, imagen 1 de 1
    • Once the battery is secured, replace the battery cover.
  6. Taylor Precision Product 3831S Kitchen Scale Battery Replacement: paso 6, imagen 1 de 1
    • Using the Phillips #00 screwdriver once again, replace the screw that secures the covering.
  7. Taylor Precision Product 3831S Kitchen Scale Battery Replacement: paso 7, imagen 1 de 1
    • Now power on the scale.
Linea de Meta
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 63
Todo El Tiempo: 4,117
