Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Tapwave T2907US Zodiac 2 Motherboard Replacement
Qué necesitas
  1. Tapwave T2907US Zodiac 2 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the four Torx T5 screws from the back panel.
  2. Tapwave T2907US Zodiac 2 Motherboard Replacement: paso 2, imagen 1 de 1
    • Wedge a spudger in between the front and back panel.
    • Apply leverage downwards to the spudger in order to remove the back panel.
  3. Tapwave T2907US Zodiac 2 Motherboard Replacement, Battery: paso 3, imagen 1 de 1
    • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
  4. Tapwave T2907US Zodiac 2 Motherboard Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
  5. Tapwave T2907US Zodiac 2 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Unscrew the 2 Philips #00 screws on each end of the motherboard.
  6. Tapwave T2907US Zodiac 2 Motherboard Replacement: paso 6, imagen 1 de 1
    • Pull off the black memory card slot piece with tweezers.
  7. Tapwave T2907US Zodiac 2 Motherboard Replacement: paso 7, imagen 1 de 1
    • Unscrew the 2 Philips #00 screws on each side of the charging port.
  8. Tapwave T2907US Zodiac 2 Motherboard Replacement: paso 8, imagen 1 de 2 Tapwave T2907US Zodiac 2 Motherboard Replacement: paso 8, imagen 2 de 2
    • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
  9. Tapwave T2907US Zodiac 2 Motherboard Replacement: paso 9, imagen 1 de 1
    • Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
    • Glue connecting the auxiliary port to the casing may make it difficult to remove. Gently apply force as needed.
  10. Tapwave T2907US Zodiac 2 Motherboard Replacement: paso 10, imagen 1 de 1
    • Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
  11. Tapwave T2907US Zodiac 2 Motherboard Replacement: paso 11, imagen 1 de 3 Tapwave T2907US Zodiac 2 Motherboard Replacement: paso 11, imagen 2 de 3 Tapwave T2907US Zodiac 2 Motherboard Replacement: paso 11, imagen 3 de 3
    • Disconnect the large brown wire-tape from the motherboard.
    • Peel the black tape back from the wire-tape using tweezers.
    • Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
    • The screen and motherboard components can now be separated from each other.
Conclusión
Equipo
Cal Poly, Team 10-33, Amido Winter 2012 Miembro de Cal Poly, Team 10-33, Amido Winter 2012
CPSU-AMIDO-W12S10G33
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 37
Todo El Tiempo: 1,423
