Introducción
Use this guide when the auxiliary port needs to be replaced.
Qué necesitas
Slide the battery out from under the brown wire-tape.
Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
Remove the solder between the auxiliary port and the motherboard carefully with the desoldering pump.
Casi Terminas!
Conclusión
