Qué necesitas
Slide the battery out from under the brown wire-tape.
Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
Herramienta utilizada en este paso:Tweezers$4.99
Use tweezers to remove analog stick straight upwards from its component on the motherboard.
It should lock into place when installing a new one.
Conclusión
