Introducción
If you find that your strings are becoming old and beginning to hurt your fingers, follow this guide in helping you to change them to some fresh ones.
Qué necesitas
Place the guitar on your lap with the strings facing up towards you.
With the same winding tool used to cut the strings, they can also be used to remove the bridge pins. Gently slide the tool under the pins and lift up on them one by one until they are all removed. From there, take out the half of the strings that are being held by them.
Grab the base of the strings (this will have brass loops) and insert them into the hole of the bridge pins one by one starting with the low-e string. Once they are inserted, slide the bridge pins back in on top of them.
Once all strings have been replaced, you may begin to tune the guitar to your desired tuning.
After the strings are tuned to where you want them, take you winder/cutter and cut off the excess string at the end.
Your guitar will now sound crisp and brand new!
