Saltar al contenido principal
Tagital T9X Volume, power, or return button Replacement
Qué necesitas
  1. Tagital T9X Volume, power, or return button Replacement, Back Cover: paso 1, imagen 1 de 1
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Volume, power, or return button Replacement: paso 2, imagen 1 de 1
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Volume, power, or return button Replacement, Volume, power, or return button: paso 3, imagen 1 de 1
    • Remove the broken volume button from the plastic case. Replace it with the new volume button, with the + being closer to the camera opening.
    • There are two other small buttons that look very similar to one another; if they fall off as well, put them back in their rightful place.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 276
