Saltar al contenido principal
Tagital T7X Motherboard Replacement
Qué necesitas
  1. Tagital T7X Motherboard Replacement, Case: paso 1, imagen 1 de 3 Tagital T7X Motherboard Replacement, Case: paso 1, imagen 2 de 3 Tagital T7X Motherboard Replacement, Case: paso 1, imagen 3 de 3
    • Place the Tagital T7X on a sturdy surface.
    • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
  2. Tagital T7X Motherboard Replacement, Speaker: paso 2, imagen 1 de 3 Tagital T7X Motherboard Replacement, Speaker: paso 2, imagen 2 de 3 Tagital T7X Motherboard Replacement, Speaker: paso 2, imagen 3 de 3
    • Remove the ribbon cable on the top left corner of the mother board.
    • Gently lift the black tape up to see the ribbon cable socket.
  3. Tagital T7X Motherboard Replacement: paso 3, imagen 1 de 3 Tagital T7X Motherboard Replacement: paso 3, imagen 2 de 3 Tagital T7X Motherboard Replacement: paso 3, imagen 3 de 3
    • Push both side buttons away from the socket by using a spudger.
  4. Tagital T7X Motherboard Replacement: paso 4, imagen 1 de 2 Tagital T7X Motherboard Replacement: paso 4, imagen 2 de 2
    • Gently pull the ribbon cable away from the socket.
    • Don't be afraid to use some force for this step.
  5. Tagital T7X Motherboard Replacement: paso 5, imagen 1 de 2 Tagital T7X Motherboard Replacement: paso 5, imagen 2 de 2
    • The soldering iron can destroy components on the motherboard. Only touch the soldering iron to the solder already on the board.
    • Touch the tip of the soldering iron to the solder connecting the positive (red) wire.
    • Pull back on the wire with the iron in place, removing it from the hot solder.
    • Repeat this step for the negative wire.
    • The solder will be melted almost instantly. There is no need to hold the iron on the solder for than a second or two. Visit IFixit's soldering guide for more info.
  6. Tagital T7X Motherboard Replacement: paso 6, imagen 1 de 2 Tagital T7X Motherboard Replacement: paso 6, imagen 2 de 2
    • Remove the speaker from the motherboard.
  7. Tagital T7X Motherboard Replacement, Battery: paso 7, imagen 1 de 2 Tagital T7X Motherboard Replacement, Battery: paso 7, imagen 2 de 2
    • Follow the attached wires to the positive and negative connections.
  8. Tagital T7X Motherboard Replacement: paso 8, imagen 1 de 3 Tagital T7X Motherboard Replacement: paso 8, imagen 2 de 3 Tagital T7X Motherboard Replacement: paso 8, imagen 3 de 3
    • Touch the tip of the soldering iron to the solder connecting the negative wire.
    • The solder will be melted almost instantly. There is no need to hold the iron on the solder for more than a second or two. Visit iFixit's soldering guide for more info.
    • Repeat this step for the positive wire.
  9. Tagital T7X Motherboard Replacement: paso 9, imagen 1 de 3 Tagital T7X Motherboard Replacement: paso 9, imagen 2 de 3 Tagital T7X Motherboard Replacement: paso 9, imagen 3 de 3
    • Use the nylon spudger to pry the battery from the back of the screen. Work your way around the edges, similar to opening the casing.
    • The adhesive used to hold the battery down is very strong. Don't be afraid to use some force.
  10. Tagital T7X Motherboard Replacement, Motherboard: paso 10, imagen 1 de 2 Tagital T7X Motherboard Replacement, Motherboard: paso 10, imagen 2 de 2
    • Next we will disconnect the digitizer ribbon cable from the motherboard.
    • Using the black spudger, gently push the tabs on each side of the socket to free the ribbon cable.
  11. Tagital T7X Motherboard Replacement: paso 11, imagen 1 de 2 Tagital T7X Motherboard Replacement: paso 11, imagen 2 de 2
    • Gently pull on the ribbon cable, separating it from the socket.
  12. Tagital T7X Motherboard Replacement: paso 12, imagen 1 de 3 Tagital T7X Motherboard Replacement: paso 12, imagen 2 de 3 Tagital T7X Motherboard Replacement: paso 12, imagen 3 de 3
    • Next, we will unscrew the three PH#0 screws anchoring the motherboard into the case.
    • You will need the Phillips Screw #0 to remove the screws of the motherboard.
    • Using the screwdriver, with the PH#0 attachment, carefully unscrew the screws of the motherboard in order to remove it from the device.
Conclusión
To reassemble your device, follow these instruction in reverse order.
2 personas más completaron esta guía.
Nikki Falato
Miembro Desde 02/10/16
254 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 2-1, Sullivan Spring 2016 Miembro de USF Tampa, Team 2-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 409
